[Geoserver-devel] [JIRA] (GEOS-7343) REST API CORS support
Hanokh Aloni created an issue
GeoServer / BugGEOS-7343
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Unassigned
Components:
REST
Created:
13/Dec/15 12:34 PM
Environment:
WIndows 7 x64 bit.
Labels:
geoserver
Priority:
MediumMedium
Reporter:
Hanokh Aloni
Add in web.xml the following filter:
<filter>
        <filter-name>cross-origin</filter-name>
        <filter-class>org.eclipse.jetty.servlets.CrossOriginFilter</filter-class>
    </filter>
    <filter-mapping>
        <url-pattern>/*</url-pattern>
    </filter-mapping>
Expected result : CORS is enabled
Actual result : the following exception:
2015-12-13 13:17:28.574:WARN:oejs.BaseHolder:main:
java.lang.ClassNotFoundException: org.eclipse.jetty.servlets.CrossOriginFilter
        at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
        at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
        at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:450)
        at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:403)
        at org.eclipse.jetty.util.Loader.loadClass(Loader.java:86)
        at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:95)
        at org.eclipse.jetty.servlet.FilterHolder.doStart(FilterHolder.java:93)
        at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
        at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:851)
        at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:298)
        at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
        at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
        at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
        at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
        at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
        at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
        at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
        at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
        at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
        at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
        at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
        at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
        at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
        at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
        at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
        at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
        at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
        at org.eclipse.jetty.server.Server.start(Server.java:387)
        at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
        at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
        at org.eclipse.jetty.server.Server.doStart(Server.java:354)
        at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
        at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
        at java.lang.reflect.Method.invoke(Method.java:606)
        at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
        at org.eclipse.jetty.start.Main.start(Main.java:817)
        at org.eclipse.jetty.start.Main.main(Main.java:112)
2015-12-13 13:17:28.584:WARN:oejuc.AbstractLifeCycle:main: FAILED cross-origin: javax.servlet.UnavailableException: org.eclipse.jetty.servlets.CrossOr
javax.servlet.UnavailableException: org.eclipse.jetty.servlets.CrossOriginFilter
        at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:102)
2015-12-13 13:17:28.604:WARN:oejs.BaseHolder:main:
        at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:888)
2015-12-13 13:17:28.614:WARN:oejuc.AbstractLifeCycle:main: FAILED cross-origin: javax.servlet.UnavailableException: org.eclipse.jetty.servlets.CrossOr
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-030#71001-sha1:2ba8c0f)
Atlassian logo
