Andrea Aime [Administrator] created an issue |
WPS cancelling output stream ends up writing a single byte at a time |
Issue Type: |
Assignee: |
Unassigned |
Components: |
WPS |
Created: |
16/Dec/15 8:05 PM |
Priority: |
Reporter: |
This is due to a design issue in the base FilterOutputStream, it turns a call to write(byte, int, int) into n calls to write(int)… which is a performance killer. We have to dodge that super method and delegate directly to the wrapped output stream instead. |
This message was sent by Atlassian JIRA (v7.1.0-OD-02-030#71001-sha1:2ba8c0f) |
