[Geoserver-devel] [JIRA] (GEOS-7349) GeoJSON geometry and geometry_name inconsistent on multi-geometry features
Andreas W created an issue
GeoServer / BugGEOS-7349
Issue Type:
BugBug
Affects Versions:
2.8.1
Assignee:
Unassigned
Components:
WFS
Created:
17/Dec/15 11:26 AM
Priority:
MediumMedium
Reporter:
Andreas W
WFS GetFeature requests for features with multiple geometries with outputFormat “json” return JSON structures as in the following sample:
  "type": "Feature",
  "id": "MyFeature.0",
  /* default geometry: */
  "geometry": {
    "type": "Point",
    "coordinates": [
      1,
      1
  "geometry_name": "geom_a",
  "properties": {
    "geom_b": {
      "type": "Point",
      "coordinates": [
        2,
        2
    "geom_c": {
      "type": "Point",
      "coordinates": [
        3,
        3
    "Title": "FeatureWithAllGeometries"
Problem: If the value of the default geometry of the feature type is null, another geometry of the feature is rendered as default geometry. However the geometry_name is still the name of the default geometry. So the geometry_name does not correspond to the default geometry of the JSON structure.
Additionally the a null value is rendered in the properties for the default geometry. This is inconsistent to behaviour shown on non-null values.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-030#71001-sha1:2ba8c0f)
Atlassian logo
