[Geoserver-devel] [JIRA] (GEOS-7360) GWC-diskquota-config exception
Daniele Romagnoli created an issue
GeoServer / BugGEOS-7360
Issue Type:
BugBug
Affects Versions:
2.9-M0
Assignee:
Unassigned
Components:
GWC
Created:
22/Dec/15 2:30 PM
Priority:
MediumMedium
Reporter:
Daniele Romagnoli
Trying to startup a clean Geoserver 2.9-trunk instance on top of a GEOSERVER_DATA_DIR based on “/data/release” geoserver’s source folder, I’m getting a DiskQuota configuration exception (see the attached log).
As far as I can see the GeoserverXMLResourceProvider.findOrCreateConfFile method has this code:
Resource xmlFile = findConfigFile();
if (Resources.exists(xmlFile))
{ log.info("Found configuration file in " + configDirectory.path()); }
else if (templateLocation != null) {
// grab template from classpath
try
{ IOUtils.copy(getClass().getResourceAsStream(templateLocation), xmlFile.out()); }
catch (IOException e)
{ throw new IOException("Error copying template config to " + xmlFile.path(), e); }
return xmlFile;
Therefore, if the file doesn’t exist and the templateLocation is null it will return that file anyway. Afterwards, the FileSystemResourceStore.in method will create an empty file and the parser will throw that exception.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-030#71001-sha1:2ba8c0f)
Atlassian logo
Hi Niels,
do you think that the JIRA I have opened right now could be related to the Resources work you made?
If that’s not the case, sorry about that: my intention was not pointing finger against someone, just trying to figure out what is going wrong.
While checking the commits history I have also found this one:
https://github.com/geoserver/geoserver/commit/e39bea39be131abda937305e6f8ebd83edf87c8a
So I’m wondering if what I have reported could be similar to that.
Best Regards,
Daniele
On Tue, Dec 22, 2015 at 2:31 PM, Daniele Romagnoli (JIRA) <jira@anonymised.com247…> wrote:
Issue Type:
BugBug
Affects Versions:
2.9-M0
Assignee:
Unassigned
Components:
GWC
Created:
22/Dec/15 2:30 PM
Priority:
MediumMedium
Reporter:
Daniele Romagnoli
try
return xmlFile;
Add Comment
Add Comment
Atlassian logo
Geoserver-devel mailing list
Geosolutions’ Winter Holidays from 24/12 to 6/1
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
