[Geoserver-devel] [JIRA] (GEOS-7362) publish 2.4.8 artifacts to maven repository
Jody Garnett [Administrator] created an issue
GeoServer / BugGEOS-7362
Issue Type:
BugBug
Affects Versions:
2.4.8
Assignee:
Unassigned
Created:
22/Dec/15 8:43 PM
Priority:
MediumMedium
Reporter:
Request from geoserver-devel mailing list - Ivan Suftin <isuftin@anonymised.com>:
I’ve checked at http://repo.boundlessgeo.com/main/ and https://boundless.artifactoryonline.com/boundless/main/ and neither repository holds the full set of artifacts for (at least) version 2.4.8 of Geoserver, including the extensions (specifically, WPS). We are currently unable to build from scratch due to this. Does anyone have an alternate Maven repository they are using for building or can someone (Andrea?) deploy the 2.4.8 version of Geoserver and extensions up?
I have confirmed that these artifacts are not available on repo.boundlessgeo.org (and checked backups).
Solution is to download the 2.4.8 release and run mvn deploy:deploy
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-02-030#71001-sha1:2ba8c0f)
Atlassian logo
