Steve Ikeoka created an issue |
Issue Type: |
Affects Versions: |
2.7.5 |
Assignee: |
Unassigned |
Components: |
WPS |
Created: |
06/Jan/16 4:49 PM |
Priority: |
Reporter: |
Executing a WPS process that takes one or more GridCoverage2D inputs will leak file handles when the process executes successfully, the input coverage is not returned as the output and the process is not internally disposing the coverage. Steps to reproduce this issue can be found here: |
This message was sent by Atlassian JIRA (v7.1.0-OD-03-049#71001-sha1:c7b15e5) |
