Justin Lewis created an issue |
Pulishing styles with GeoServer Rest API strips out CDATA[ ] (notice the white space in CDATA[]) |
Issue Type: |
Affects Versions: |
2.5 |
Assignee: |
Unassigned |
Components: |
REST, WMS |
Created: |
13/Jan/16 8:56 PM |
Environment: |
Ubuntu Linux 15.04, Geoserver 2.5, Geoserver Manager 1.5.3 |
Labels: |
SLD geoserver |
Priority: |
Reporter: |
We use the GeoServer Rest API to publish styles. A style can have a label with two properties concatenated together and separated by a space. In the SLD we are submitting: <sld:Label> However, the end label result is the two properties are concatenated together without the space. It looks like the Rest API is stripping out <![CDATA]>, so the SLD that is actually on the server is defined as: <sld:Label> Thus, when the layer is rendered the empty <ogc:Literal> tag results in no space being concatenated. |
This message was sent by Atlassian JIRA (v7.1.0-OD-04-012#71001-sha1:dd0493d) |
