Orosz Gabor created an issue |
Issue Type: |
Affects Versions: |
2.8.1 |
Assignee: |
Unassigned |
Components: |
Oracle, REST |
Created: |
21/Jan/16 11:54 AM |
Priority: |
Reporter: |
Hi! I use 1.7-SNAPSHOT gs manager. <dependency> If i create layer from store(with filter /sql view/), and i publish the new layer, the publishing works(its all from java with the geoserver manager api on gs rest). But the layer preview not working. If i check the “Guess geometry type and srid” and refresh, and i check the correct “Identifier”, its will working. |
This message was sent by Atlassian JIRA (v7.1.0-OD-05-006#71001-sha1:081cc1a) |
