Andrea Aime [Administrator] created an issue |
Disk quota JDBC connection pool saved even if the JNDI approach is chosen |
Issue Type: |
Assignee: |
Unassigned |
Components: |
GWC, Wicket UI |
Created: |
26/Jan/16 11:41 AM |
Priority: |
Reporter: |
The GUI does not lose the information about the connection pool to avoid forcing the user to re-enter all the data in case they flip back and forth between JNDI and local connection pool, however on save it should discard the bits that were not chosen. |
This message was sent by Atlassian JIRA (v7.1.0-OD-05-006#71001-sha1:081cc1a) |
