[Geoserver-devel] [JIRA] (GEOS-7394) Intermittent build failure in gs-web-sec-core NewDataAccessRulePageTest.testDuplicateRule
Ben Caradoc-Davies [Administrator] created an issue
GeoServer / BugGEOS-7394
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Unassigned
Components:
UI
Created:
29/Jan/16 10:46 PM
Priority:
MediumMedium
Reporter:
The build often fails on ares, winbuild, and locally with this failure:
testDuplicateRule(org.geoserver.security.web.data.NewDataAccessRulePageTest)  Time elapsed: 420 sec  <<< FAILURE!
java.lang.AssertionError: expected no error message, but contains
   Rule cite.Bridges.w already exists in the rule list
	at org.junit.Assert.fail(Assert.java:88)
	at org.junit.Assert.assertTrue(Assert.java:41)
	at org.junit.Assert.assertFalse(Assert.java:64)
	at org.apache.wicket.util.tester.WicketTester.assertNoFeedbackMessage(WicketTester.java:659)
	at org.apache.wicket.util.tester.WicketTester.assertNoErrorMessage(WicketTester.java:639)
	at org.geoserver.security.web.data.NewDataAccessRulePageTest.testDuplicateRule(NewDataAccessRulePageTest.java:112)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-05-006#71001-sha1:081cc1a)
Atlassian logo
