I have a mosaic layer which ends up using WrappedSampleDimension for some reason.
I also have a custom style, which invokes OperationJAI#deriveSampleDimension at some point. (stack trace below)
Now this second operation assumes that SampleDimension#getCategories()#toArray()
returns a Category, which is true for the default GridSampleDimension implementation, but not for WrappedSampleDimension. Hence the ClassCastException below occurs. Of course, this could also be fixed in OperationJAI.
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:344)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:259)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:505)
at org.geoserver.wms.GetMap.run(GetMap.java:249)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor226.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy34.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor183.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:698)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1506)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1494)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:95)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at be.vito.eo.geoserverhdf5.OpenAMSimpleCookieFilter.OpenAMSimpleCookieFilter.doFilter(OpenAMSimpleCookieFilter.java:60)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1486)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:503)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:138)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:564)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:213)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1096)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:432)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:175)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1030)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:136)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:445)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:268)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:229)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.run(AbstractConnection.java:358)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:601)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:532)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Lorg.geotools.coverage.Category;
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1055)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:342)
... 105 more
Caused by: java.lang.RuntimeException: Failed to evaluate the process function, error is: java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Lorg.geotools.coverage.Category;
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:155)
at org.geotools.renderer.lite.RenderingTransformationHelper.applyRenderingTransformation(RenderingTransformationHelper.java:185)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1008)
... 106 more
Caused by: org.geotools.process.ProcessException: java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Lorg.geotools.coverage.Category;
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:565)
at org.geotools.process.function.ProcessFunction.evaluate(ProcessFunction.java:142)
... 108 more
Caused by: java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Lorg.geotools.coverage.Category;
at org.geotools.coverage.processing.OperationJAI.deriveSampleDimension(OperationJAI.java:787)
at org.geotools.coverage.processing.OperationJAI.deriveGridCoverage(OperationJAI.java:580)
at org.geotools.coverage.processing.OperationJAI.doOperation(OperationJAI.java:314)
at org.geotools.coverage.processing.CoverageProcessor.doOperation(CoverageProcessor.java:605)
at be.vito.tap.mosaic.MultiplyConstCoverage.execute(MultiplyConstCoverage.java:75)
at sun.reflect.GeneratedMethodAccessor235.invoke(Unknown Source)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:549)
... 109 more
