[Geoserver-devel] [JIRA] (GEOS-7398) Unable to create cached layer
Christian Ehrlicher created an issue
GeoServer / BugGEOS-7398
Issue Type:
BugBug
Affects Versions:
2.8.2
Assignee:
Unassigned
Components:
GWC
Created:
03/Feb/16 12:45 PM
Environment:
Linux 64 bit, jdk 1.8.0-72, Platform independent binary
Priority:
MediumMedium
Reporter:
Christian Ehrlicher
I’m adding a ImageMosaic Data Source with some raster data created with gdal_retile.py
All works fine but gwc won’t create tiles with the following backtrace:
Feb 03, 2016 12:34:47 PM org.geoserver.GeoserverInitStartupListener$1 errorOccurred
INFORMATION: Problem occurs when computing a tile by the owner.
java.awt.image.RasterFormatException: Incorrect pixel stride: 4
at sun.awt.image.ByteComponentRaster.verify(ByteComponentRaster.java:920)
at sun.awt.image.ByteComponentRaster.<init>(ByteComponentRaster.java:201)
at sun.awt.image.ByteInterleavedRaster.<init>(ByteInterleavedRaster.java:191)
at sun.awt.image.ByteInterleavedRaster.<init>(ByteInterleavedRaster.java:113)
at java.awt.image.Raster.createWritableRaster(Raster.java:980)
at javax.media.jai.RasterFactory.createWritableRaster(RasterFactory.java:712)
at javax.media.jai.RasterFactory.createWritableRaster(RasterFactory.java:691)
at org.geoserver.jai.PassThroughTileFactory.createTile(PassThroughTileFactory.java:72)
at javax.media.jai.PlanarImage.createWritableRaster(PlanarImage.java:1982)
at javax.media.jai.PointOpImage.computeTile(PointOpImage.java:771)
at com.sun.media.jai.util.SunTileScheduler.scheduleTile(SunTileScheduler.java:904)
at javax.media.jai.OpImage.getTile(OpImage.java:1129)
at javax.media.jai.PlanarImage.getData(PlanarImage.java:2085)
at javax.media.jai.RenderedOp.getData(RenderedOp.java:2276)
at javax.media.jai.PlanarImage.getExtendedData(PlanarImage.java:2440)
at com.sun.media.jai.opimage.MosaicOpImage.computeTile(MosaicOpImage.java:437)
at javax.media.jai.PlanarImage.copyData(PlanarImage.java:2343)
at javax.media.jai.PlanarImage.copyExtendedData(PlanarImage.java:2398)
at javax.media.jai.PlanarImage.getExtendedData(PlanarImage.java:2459)
at com.sun.media.jai.opimage.MosaicOpImage.computeTile(MosaicOpImage.java:432)
at javax.media.jai.RenderedOp.copyData(RenderedOp.java:2299)
at org.geoserver.gwc.layer.GeoServerMetaTile.createTile(GeoServerMetaTile.java:192)
at org.geoserver.gwc.layer.GeoServerMetaTile.writeTileToStream(GeoServerMetaTile.java:98)
at org.geowebcache.layer.TileLayer.saveTiles(TileLayer.java:655)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:572)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:764)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
I first thought the complete dataset was too big (~60000x60000) but it doesn’t work with a smaller area (23000x20000) too
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-05-006#71001-sha1:081cc1a)
Atlassian logo
