[Geoserver-devel] [JIRA] (GEOS-7419) java.lang.IllegalArgumentException: Type name not found: null on GS 2.8.2 and GT 14.2
Cosmin Spinu created an issue
GeoServer / BugGEOS-7419
Issue Type:
BugBug
Affects Versions:
2.8.2
Assignee:
Unassigned
error_null.txt
Components:
WFS
Created:
09/Feb/16 2:08 PM
Priority:
MediumMedium
Reporter:
Cosmin Spinu
[It is somehow the same flow as for https://osgeo-org.atlassian.net/browse/GEOS-7416 but different error.]
I needed to upgrade from GS 2.7.2 + GT 13 at 2.8.2 + GT 14.2 due to some problems in 2.7.2 of using outgoing proxy for WFS layers. I noticed that these versions are very instable.
I use geoserver deployed into a JBoss and all these versions are managed in pom.xml
I noticed an inconsistent behavior when starting/restarting JBoss when I encounter the attached error without any intervention on the war file deployed. Just restart JBoss EAP 6.2 or 6.4 several times.
This error is dissapering after several restarts, again without intervene on war file. And it is appearing again after restart and so on. It is very annoying that the behaviour is inconsistent.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.1.0-OD-06-005#71002-sha1:1d15c98)
Atlassian logo
