[Geoserver-devel] [JIRA] (GEOS-7424) Support new GeoTools local date handling
Andreas W created an issue
GeoServer / BugGEOS-7424
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Unassigned
Components:
WFS
Created:
16/Feb/16 11:35 AM
Priority:
HighHigh
Reporter:
Andreas W
The upcoming GeoServer shall support the local date handling newly introduced in GeoTools 15.0.
The prior fix for avoiding time zone related date shifting must be changed, so that GeoServer behaviour depends on a GeoTools configuration parameter:
Setting a system property
-Dorg.geotools.localDateTimeHandling=true
will make GeoServer treat all java.sql.Date instances as local dates unaware of time zones.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-01-031#72000-sha1:c6b05a6)
Atlassian logo
