[Geoserver-devel] [JIRA] (GEOS-7435) Inconsistent encoding assumptions in GeoServerSystemTestSupport cause build failure on Windows
Ben Caradoc-Davies [Administrator] created an issue
GeoServer / BugGEOS-7435
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Components:
Main
Created:
24/Feb/16 12:31 AM
Priority:
HighestHighest
Reporter:
GeoServerSystemTestSupport often uses String.getBytes which uses the system default charset, but GeoServerSystemTestSupport.dom uses an InputSource which assumes UTF-8 unless told otherwise with InputSource.setEncoding.
This defect causes a build failure on Windows, which can be reproduced on Linux by invoking Maven with -Djvm.opts=“-Dfile.encoding=windows-1252” :
Tests in error:
   testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest):
Invalid byte 2 of 3-byte UTF-8 sequence.
This Winbuild stack trace shows the failure on Windows:
testSpecialCharacterNames(org.geoserver.rest.resources.ResourceTest)  Time elapsed: 203 sec  <<< ERROR!
com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 2 of 3-byte UTF-8 sequence.
	at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.invalidByte(UTF8Reader.java:701)
	at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(UTF8Reader.java:408)
	at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(XMLEntityScanner.java:1790)
	at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipChar(XMLEntityScanner.java:1460)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2824)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
	at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:118)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:243)
	at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)
	at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1391)
	at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1372)
	at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1264)
	at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1199)
	at org.geoserver.rest.resources.ResourceTest.testSpecialCharacterNames(ResourceTest.java:161)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-02-009#72000-sha1:d162675)
Atlassian logo
