[Geoserver-devel] [JIRA] (GEOS-7436) Invalid directory timestamp assumptions in ResourceTest break build on Windows
Ben Caradoc-Davies [Administrator] created an issue
GeoServer / BugGEOS-7436
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Components:
REST
Created:
24/Feb/16 1:59 AM
Priority:
HighestHighest
Reporter:
ResourceTest.testDirectory* tests compare the Resource.lastmodified of a directory against myRes.lastmodified, the Resource.lastmodified of its child. While these timestamps may be expected to be the same on Linux, this assumption does not appear to hold on Windows, where small timestamp discrepancies (milliseconds) result in failures such as:
Failed tests:   testDirectoryXML(org.geoserver.rest.resources.ResourceTest): expected:<2016-02-23 22:47:38.[34] UTC> but was:<2016-02-23 22:47:38.[49] UTC>
  testDirectoryJSON(org.geoserver.rest.resources.ResourceTest): objects differed at key [ResourceDirectory];: objects differed at key [lastModified]; expected:<...016-02-23 22:47:38.1[59] UTC> but was:<...016-02-23 22:47:38.1[74] UTC>
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-02-009#72000-sha1:d162675)
Atlassian logo
