Federico Guizzardi created an issue |
Issue Type: |
Affects Versions: |
2.8.2 |
Assignee: |
Unassigned |
Components: |
REST |
Created: |
02/Mar/16 12:54 PM |
Environment: |
CentOS 6.5, Tomcat 7 |
Priority: |
Reporter: |
I found a bug related the list of styles in a layergroup json.
Step to reproduce:
- run a geoserver (tested with 2.6.1 and 2.8.2)
- connect to …/geoserver/web and make login
- go to Layer Groups and add a new one (called example001) with, at least, three layer with default style checked for every ones
- go to …/geoserver/rest/layergroups/example001.json
- If you look at the file, you can see somthing like
“styles”:
{“style”:[“”]}
,“style”:[“”,“”]
that is a little bit different compared with expectation. I think it would be somthing like this:
“styles”:
{“style”:[“”,“”,“”]}
An interesting thing: looking the same layergroup using XML instead JSON there’s no problem.
Thanks for support.
This message was sent by Atlassian JIRA (v7.2.0-OD-03-010#72000-sha1:d4f0e55) |
