[Geoserver-devel] [JIRA] (GEOS-7444) Updating a coverage using REST API fails if JSON (or XML) payload doesn't follow a specific order
Cesar Martinez created an issue
GeoServer / BugGEOS-7444
Updating a coverage using REST API fails if JSON (or XML) payload doesn’t follow a specific order
Issue Type:
BugBug
Affects Versions:
2.9-beta, 2.8.2, 2.7.6
Assignee:
Unassigned
Components:
Main
Created:
03/Mar/16 3:19 PM
Environment:
java version “1.8.0_74”
Java™ SE Runtime Environment (build 1.8.0_74-b02)
Java HotSpot™ 64-Bit Server VM (build 25.74-b02, mixed mode)
Priority:
MediumMedium
Reporter:
Cesar Martinez
Updating a coverage using REST API fails if JSON (or XML) payload doesn’t follow a specific order. This is a problem as JSON objects don’t follow a specific order by definition.
The problem is caused by XStreamPersister.java, which is assuming a specific order for GridGeometry2D unmarshalling.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-03-010#72000-sha1:d4f0e55)
Atlassian logo
