Go Sato created an issue |
Issue Type: |
Affects Versions: |
2.9-beta |
Assignee: |
Unassigned |
Components: |
Documentation |
Created: |
03/Mar/16 4:07 PM |
Environment: |
All web browsers |
Priority: |
Reporter: |
In the Filter Function Reference section of GeoServer documentation (http://docs.geoserver.org/latest/en/user/filter/function_reference.html), two fixes might be needed A. The order of parameters of numberFormat function looks misleading. This function works when the format is set at the first child node and the number is at the second like below. <ogc:Function name=“numberFormat”> What the current document is suggesting is that the number is the first parameter and the format second. I think they should be switched. B. Math function “sin” is not documented whilst “cos” and “tan” are. |
This message was sent by Atlassian JIRA (v7.2.0-OD-03-010#72000-sha1:d4f0e55) |
