[Geoserver-devel] [JIRA] (GEOS-7453) REST API PUT featuretype request disables layer
Torben Barsballe created an issue
GeoServer / BugGEOS-7453
Issue Type:
BugBug
Affects Versions:
2.8.2, 2.7.6, 2.6.5
Assignee:
Torben Barsballe
Components:
REST
Created:
10/Mar/16 7:08 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
When doing a PUT request against a feature type to change the cqlFilter, any layers backed by that featureType get disabled.
curl -v -u admin:geoserver -XPUT -H "Content-type: text/xml" http://localhost:8080/geoserver/rest/workspaces/sf/datastores/sf/featuretypes/roads -d "<featureType><cqlFilter>label=''</cqlFilter></featureType>"
It looks like this occurs because GeoServer is constructing a new FeatureTypeInfo object from the request parameters, then copying all non-null values to the FeatureTypeInfo object in the catalog. Since enabled is a boolean primitive, it is initialized to false and copied, casing the FeatureTypeInfo object to become disabled.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-03-014#72000-sha1:1e7aa97)
Atlassian logo
