Landry Breuil created an issue |
Issue Type: |
Affects Versions: |
2.8.2 |
Assignee: |
Unassigned |
Components: |
Global |
Created: |
14/Mar/16 10:51 AM |
Environment: |
Tomcat 8, debian jessie |
Priority: |
Reporter: |
The xslt extension uses System.out.println() to print debugging info instead of properly using geoserver logging, which can uselessly fill out catalina.out. While i can understand system.out.println() being used in tests, it shouldn’t appear in production code… https://github.com/geoserver/geoserver/search?utf8=%E2%9C%93&q=%22System.out.println%22&type=Code |
This message was sent by Atlassian JIRA (v7.2.0-OD-03-014#72000-sha1:1e7aa97) |
