[Geoserver-devel] [JIRA] (GEOS-7471) Monitoring extension missing class javassist/util/proxy/MethodFilter
Torsten Heinen created an issue
GeoServer / BugGEOS-7471
Issue Type:
BugBug
Affects Versions:
2.8.2
Assignee:
Unassigned
Created:
22/Mar/16 12:55 PM
Priority:
MediumMedium
Reporter:
Torsten Heinen
When installing the monitoring extension with hibernate in GeoServer 2.8.2, GeoServer fails to start due to a CNF exception (javassist/util/proxy/MethodFilter, see below).
Downloading javassist 3.12.1 from maven central and adding it WEB-INF/lib solves the problems.
2016-03-21 18:09:01,938 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'controlFlowCallbackProxy' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-core-2.8.2.jar!/applicationContext.xml]: Cannot resolve reference to bean 'monitor' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'monitor' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-core-2.8.2.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.monitor.Monitor]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibMonitorDAO' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.8.2.jar!/applicationContext-hib2.xml]: Cannot resolve reference to bean 'hibSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibSessionFactory' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.8.2.jar!/applicationContext-hib2.xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: javassist/util/proxy/MethodFilter
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
        at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
        at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.context.support.AbstractApplicationContext.registerBeanPostProcessors(AbstractApplicationContext.java:746)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:457)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
        at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4812)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5255)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
        at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:585)
        at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1794)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'monitor' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-core-2.8.2.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.monitor.Monitor]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibMonitorDAO' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.8.2.jar!/applicationContext-hib2.xml]: Cannot resolve reference to bean 'hibSessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hibSessionFactory' defined in URL [jar:file:/opt/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.8.2.jar!/applicationContext-hib2.xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: javassist/util/proxy/MethodFilter
        at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:288)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
        ... 30 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-04-029#72002-sha1:f50e4de)
Atlassian logo
