[Geoserver-devel] [JIRA] (GEOS-7472) Fails to start in Tomcat with extensions installed
Kevin Smith created an issue
GeoServer / BugGEOS-7472
Issue Type:
BugBug
Assignee:
Unassigned
Created:
24/Mar/16 11:55 PM
Environment:
Tomcat
Priority:
HighestHighest
Reporter:
Kevin Smith
Occurs with a collection of extensions installed post spring 4 update.
This appears to be a result of Tomcat doing an annotation scan of the classpath. We can probably fix it by disabling the scan http://stackoverflow.com/a/12730059/688999
SEVERE: ContainerBase.addChild: start:
org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[]]
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
	at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1095)
	at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1617)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.tomcat.util.bcel.classfile.ClassFormatException: Invalid byte tag in constant pool: 18
	at org.apache.tomcat.util.bcel.classfile.Constant.readConstant(Constant.java:131)
	at org.apache.tomcat.util.bcel.classfile.ConstantPool.<init>(ConstantPool.java:60)
	at org.apache.tomcat.util.bcel.classfile.ClassParser.readConstantPool(ClassParser.java:209)
	at org.apache.tomcat.util.bcel.classfile.ClassParser.parse(ClassParser.java:119)
	at org.apache.catalina.startup.ContextConfig.processAnnotationsStream(ContextConfig.java:2032)
	at org.apache.catalina.startup.ContextConfig.processAnnotationsJar(ContextConfig.java:1923)
	at org.apache.catalina.startup.ContextConfig.processAnnotationsUrl(ContextConfig.java:1891)
	at org.apache.catalina.startup.ContextConfig.processAnnotations(ContextConfig.java:1877)
	at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1270)
	at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:855)
	at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:345)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
	at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5161)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	... 10 more
Mar 24, 2016 2:57:02 PM org.apache.catalina.startup.HostConfig deployDirectory
SEVERE: Error deploying web application directory /var/lib/tomcat7/webapps/ROOT
java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[]]
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:898)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-04-029#72002-sha1:f50e4de)
Atlassian logo
