Assigning a style from a read-protected workspace using JMS clustering causes ServiceException java.lang.NullPointerException, either using Admin UI or REST interface. This report will show how to reproduce using the Admin UI:
Verify clustering is working properly:
- use the Admin UI on node 1 to generate a new style e.g. ‘orange’ under workspace ‘topp’ for type ‘polygon’
- verify style is present on node 2
- on node 1, under tab Publishing modify default style of ‘topp:tasmania_state_boundaries’ to ‘topp:orange’
- on node 1, verify ‘tasmania_state_boundaries’ uses the new style using the layer preview (mind image caching, drag or zoom a bit)
- on node 2, verify ‘tasmania_state_boundaries’ uses the new style using the layer preview (mind image caching, drag or zoom a bit)
Reproduce the issue:
- node 1 and 2: under security->data, add new rule
workspace: ‘topp’, layer: ‘*’, access mode: ‘read’, selected role: ‘GROUP_ADMIN’
- repeat 1-5 above with a new style e.g. ‘yellow’ within workspace ‘topp’.
RESULT: The new style is active in layer preview on node 1, node 2 FAILs to draw images, in cases causes GetCapabilities to issue an NPE as well.
Interestingly, the ‘yellow’ style IS present on node 2, and when viewing the Publishing tab of the offending layer on node 2, it does show the ‘topp:yellow’ style.
Log on node 2
> 2016-03-30 10:35:29,401 ERROR [org.geoserver.ows] (http-10.95.37.114-8080-5)
> at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:102)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:606)
> at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
> at com.sun.proxy.$Proxy265.getStyle(Unknown Source)
> at org.geoserver.wms.map.GetMapKvpRequestReader.getDefaultStyle(GetMapKvpRequestReader.java:569)
> at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:396)
> at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:84)
> at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1493)
> at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:681)
> at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:265)
> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
> at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
> at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
> at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
> at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:138)
> at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:95)
> at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
> at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
> at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
> at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
> at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
> at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
> at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
> at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
> at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
> at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
> at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
> at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
> at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
> at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
> at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
> at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
> at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
> at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
> at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
> at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
> at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
> at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:183)
> at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:95)
> at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
> at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
> at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
> at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
> at org.jboss.web.tomcat.service.request.ActiveRequestResponseCacheValve.internalProcess(ActiveRequestResponseCacheValve.java:74)
> at org.jboss.web.tomcat.service.request.ActiveRequestResponseCacheValve.invoke(ActiveRequestResponseCacheValve.java:47)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
> at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
> at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:599)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:451)
> at java.lang.Thread.run(Thread.java:745)
