[Geoserver-devel] [JIRA] (GEOS-7478) WFS-T data are not inserted but SUCCESS is returned
Alessandro Pasotti created an issue
GeoServer / BugGEOS-7478
Issue Type:
BugBug
Affects Versions:
2.8.2
Assignee:
Unassigned
Components:
WFS
Created:
30/Mar/16 1:25 PM
Environment:
Build Information
Version
2.8.2
Git Revision
f1366aa5e0c9d477b9c6a05fd31d59e0e81985f9
Build Date
23-Jan-2016 02:21
GeoTools Version
14.2 (rev 73d5c95ed430b6c891eb2f0dfebb742ba01780fe)
GeoWebCache Version
1.8.1 (rev f22447f59ca37f72bfe6bc746d834b0e73e7c3fc/f22447f59ca37f72bfe6bc746d834b0e73e7c3fc)
Labels:
wfs
Priority:
HighHigh
Reporter:
Alessandro Pasotti
I’m testing the official geoserver 2.8.2 on Linux, I’ve enabled WFS-T transactional on all workspaces.
I’m doing some insert tests using topp: roads, state_boundaries and cities as test layers for linestrings, polygons and points.
Using QGIS as a client, this works:
  • insert on cities
This doesn’t:
  • insert on roads and state_boundaries
First issue: geoserver returns <wfs:SUCCESS/> (no errors and no warnings in the logs) but data are not inserted in the shapefiles.
By comparing example XML I’ve tracked down the problem (at least for linestrings) to the simple GML used by QGIS, compared with the multi geometry GML used in the geoserver demo requests (which works):
QGIS (silently fails):
{{<the_geom xmlns=“http://www.openplans.org/topp”>
<gml:LineString srsName=“EPSG:4326”>
<gml:coordinates cs=“,” ts=" ">146.1911…
GeoServer Demo Requests (works):
{{<topp:the_geom>
<gml:MultiLineString srsName=“http://www.opengis.net/gml/srs/epsg.xml#4326”>
<gml:lineStringMember>
<gml:LineString>
<gml:coordinates decimal=“.” cs=“,” ts=" ">146.1911…
I believe that geoserver should not return <wfs:SUCCESS/> if data are not saved
Attached transaction (Jira refused to accept this upload, that’s why I’m attaching inline):
{{<Transaction xmlns=“http://www.opengis.net/wfs” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.0.0” xmlns:topp=“http://www.openplans.org/topp” service=“WFS” xsi:schemaLocation=“http://www.openplans.org/topp http://localhost:8080/geoserver/topp/wfs?SERVICE=WFS&amp;VERSION=1.0.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=topp:tasmania_roads&amp;SRSNAME=EPSG:4326&amp;username=admin&amp;password=geoserver” xmlns:gml=“http://www.opengis.net/gml”>
<Insert xmlns=“http://www.opengis.net/wfs”>
<tasmania_roads xmlns=“http://www.openplans.org/topp”>
<TYPE xmlns=“http://www.openplans.org/topp”>halley</TYPE>
<gml:coordinates cs=“,” ts=" ">146.19112816620227591,-41.66950710727635965 146.50087137079171384,-41.78901432794472015 146.86670980140911524,-41.77194186784923602 146.98133917633592205,-41.9963227719612604 146.98133917633592205,-42.24021505903954221 146.77403073231937469,-42.16216952717449118 146.54233305959502331,-41.98412815760734418 146.31063538687064352,-41.94754431454560262 146.09113232850017994,-41.96705569751186715 145.87894603874207178,-41.86218201406820327 145.883823884483661,-41.73535802478749446 145.94479695625321369,-41.62072864986070186 146.13991078591584483,-41.62560649560226977</gml:coordinates>
</gml:LineString>
</the_geom>
</tasmania_roads>
</Insert>
</Transaction>
Response:
{{<wfs:WFS_TransactionResponse version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd”><wfs:InsertResult><ogc:FeatureId fid=“new0”/></wfs:InsertResult><wfs:TransactionResult><wfs:Status><wfs:SUCCESS/></wfs:Status></wfs:TransactionResult></wfs:WFS_TransactionResponse>
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-04-029#72002-sha1:f50e4de)
Atlassian logo
