Jukka Rahkonen created an issue |
Issue Type: |
Affects Versions: |
2.9-beta |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
05/Apr/16 11:30 PM |
Environment: |
The Windows startup.bat that is shipped with bin-zip package fails to start GS 2.9 on Windows. The reason has been located to “%JAVA_OPTS%” variable which is in the startup.bat literally as above with double quotas. Removing the quotas seems to be a reliable fix. Nightly builds of Master lack the Windows installer (exe) but probably it is creating also a non-operational start command. The issue is a side effect of removing this line from startup.bat because Java 8 does not have MaxPermSize: if “%JAVA_OPTS%” == “” (set JAVA_OPTS=-XX:MaxPermSize=128m) Discussion on the mailing list is inside another mail thread but a mail by Chris Snider contains all the details except the explanation why it worked until GS 2.9: http://thread.gmane.org/gmane.comp.gis.geoserver.devel/32999/focus=33354 |
Priority: |
Reporter: |
This message was sent by Atlassian JIRA (v7.2.0-OD-05-023#72002-sha1:6298ce2) |
