[Geoserver-devel] [JIRA] (GEOS-7486) Connection refused
CKA3KuH created an issue
GeoServer / BugGEOS-7486
Connection refused
Issue Type:
BugBug
Affects Versions:
2.8.3
Assignee:
Unassigned
Created:
06/Apr/16 11:53 AM
Environment:
http://env-0306636.pai.ontopcorp.com/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.wps.web.WPSRequestBuilder
Priority:
MediumMedium
Reporter:
CKA3KuH
Here is the URL: http://env-0306636.pai.ontopcorp.com/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.wps.web.WPSRequestBuilder
Select JTS area, and then “Execute process”. U will see the error displayed.All the process give the same error.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-05-023#72002-sha1:6298ce2)
Atlassian logo
