Nuno Oliveira created an issue |
Issue Type: |
Affects Versions: |
2.9-beta, 2.8.3 |
Assignee: |
Components: |
GeoFence |
Created: |
13/Apr/16 3:47 PM |
Fix Versions: |
2.9-beta2, 2.8.4 |
Priority: |
Reporter: |
When using geofence-geoserver module (embedded mode) module properties are not correctly saved. To reproduced the error change some properties in the UI (GeoFence Admin Page), submit the changes and restart geoserver instance. The changed changed propeties will not appear in the UI. |
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a) |
