Duncan Clotfelter created an issue |
Issue Type: |
Affects Versions: |
2.8.3 |
Assignee: |
Unassigned |
Created: |
13/Apr/16 8:22 PM |
Environment: |
Windows 2012 R2 |
Priority: |
Reporter: |
When a proxy is set, the log in/log out buttons ignore it and redirect the user to the original page. A temporary solution was implemented on a local copy through editing org.geoserver.security.filter.GeoServerUserPasswordAuthenticationFilter and org.geoserver.security.filter.GeoServerLogoutFilter by hardcoding URL_LOGIN_SUCCESS, URL_LOGIN_FAILURE, and URL_AFTER_LOGOUT to absolute paths, and setting redirectUrl to always be the previously stated constant. |
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a) |
