[Geoserver-devel] [JIRA] (GEOS-7497) Restricting security on layers breaks aggregate visitor optimizations in JDBC stores
Andrea Aime [Administrator] created an issue
GeoServer / BugGEOS-7497
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Main, WPS
Created:
14/Apr/16 3:44 PM
Priority:
MediumMedium
Reporter:
Normally processes such as PagedUnique and Aggregate run as optimized sql statements, but applying security restrictions on the layers makes them fall back on data loading and in memory aggregatation insetad.
This is due to DecoratingFeatureCollection not delegating down the visit method (which is the right decision) and subclasses not taking measures to check if the visitor can be passed down, or not.
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/security/decorators/SecuredSimpleFeatureCollection.java is one of those, but retyping (used in renames) and reprojecting/forcecrs collections are also causing the problem.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a)
Atlassian logo
