Matt Bertrand created an issue |
ImageMosaic creation/update very slow when database has many tables |
Issue Type: |
Assignee: |
Unassigned |
Created: |
15/Apr/16 6:54 PM |
Environment: |
Ubuntu 14.04, OS X |
Priority: |
Reporter: |
After upgrading Geoserver from 2.7.4 to 2.8.2, updating existing image mosaics or creating new ones (with configuration saved in a PostGIS DB having thousands of other tables) became extremely slow and hung up other Geoserver until completed. I tracked the problem down to this line in Geotools, which causes every table in the database to be examined. I am not sure if this is working as designed, but a workaround is to add “TypeNames=false” to the image mosaic’s datastore.properties file, which will prevent this code block from being called. This should probably be included in the ImageMosaic documentation. |
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a) |
