[Geoserver-devel] [JIRA] (GEOS-7501) Convert function in sldService module creates unrenderable SLD rules
Matt Bertrand created an issue
GeoServer / BugGEOS-7501
Issue Type:
BugBug
Affects Versions:
2.9-beta
Assignee:
Unassigned
Components:
Community modules
Created:
15/Apr/16 9:53 PM
Environment:
OSX, Ubuntu 14.04
Priority:
MediumMedium
Reporter:
Matt Bertrand
PR with potential fix: https://github.com/geoserver/geoserver/pull/1571
Use parseDouble instead of convert function to create renderable sld rules, and only if ‘normalize’ boolean is true.
The ‘convert’ function creates SLD rules that are not renderable (exception included at bottom):
        <PropertyIsGreaterThanOrEqualTo>
          <Function name="convert">
            <PropertyName>value</PropertyName>
            <Literal>java.lang.Double</Literal>
          </Function>
          <Literal>220.0</Literal>
        </PropertyIsGreaterThanOrEqualTo>
Switching to ‘parseDouble’ produces renderable SLD:
          <Function name="parseDouble">
          </Function>
The exception caused by the convert function is:
Caused by: java.lang.IllegalArgumentException: Filter Function problem for function convert argument #1 - expected type Class
	at org.geotools.filter.function.FilterFunction_Convert.evaluate(FilterFunction_Convert.java:51)
	at org.geotools.filter.FilterAbstract.eval(FilterAbstract.java:95)
	at org.geotools.filter.MultiCompareFilterImpl.evaluate(MultiCompareFilterImpl.java:64)
	at org.geotools.filter.AndImpl.evaluate(AndImpl.java:44)
	at org.geotools.filter.OrImpl.evaluate(OrImpl.java:41)
	at org.geotools.data.FilteringFeatureReader.hasNext(FilteringFeatureReader.java:133)
	at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.hasNext(ContentFeatureCollection.java:143)
	at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2294)
	at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1917)
	at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:833)
	at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:548)
	... 112 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a)
Atlassian logo
