Jody Garnett [Administrator] created an issue |
Issue Type: |
Affects Versions: |
2.9-beta2 |
Assignee: |
Unassigned |
Components: |
release |
Created: |
20/Apr/16 12:40 AM |
Priority: |
Reporter: |
The startup.bat has been updated to detect and use the system java (if JAVA_HOME is not set). The shutdown.bat file has not had this fix. This provides an awkward setup where you can start geoserver, but not stop it. |
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a) |
