[Geoserver-devel] [JIRA] (GEOS-7508) Unable to start DMG due to spring-security exception
Jody Garnett [Administrator] created an issue
GeoServer / BugGEOS-7508
Issue Type:
BugBug
Assignee:
Unassigned
Created:
20/Apr/16 2:06 AM
Priority:
MediumMedium
Reporter:
As per email unable to start DMG based on the following stack trace:
18 Apr 21:30:25 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
2016-04-18 21:30:25.694:WARN:oejw.WebAppContext:startup executor: Failed startup of context o.e.j.w.WebAppContext@anonymised.com
Unknown macro: {/geoserver,file}
Unknown macro: {/geoserver}
org.springframework.beans.factory.BeanCreationException: Error occured reading security configuration; nested exception is java.lang.RuntimeException: org.jasypt.exceptions.EncryptionOperationNotPossibleException: Encryption raised an exception. A possible cause is you are using strong encryption algorithms and you have not installed the Java Cryptography Extension (JCE) Unlimited Strength Jurisdiction Policy Files in this Java Virtual Machine
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:417)
at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:163)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:136)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:381)
at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:335)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:26)
Caused by:
at org.geoserver.security.GeoServerSecurityManager.getMasterPassword(GeoServerSecurityManager.java:1866)
at org.geoserver.security.KeyStoreProviderImpl.assertActivatedKeyStore(KeyStoreProviderImpl.java:234)
at org.geoserver.security.KeyStoreProviderImpl.reloadKeyStore(KeyStoreProviderImpl.java:101)
at org.geoserver.security.concurrent.LockingKeyStoreProvider.reloadKeyStore(LockingKeyStoreProvider.java:80)
at org.geoserver.security.GeoServerSecurityManager.init(GeoServerSecurityManager.java:577)
at org.geoserver.security.GeoServerSecurityManager.init(GeoServerSecurityManager.java:568)
at org.geoserver.security.GeoServerSecurityManager.onApplicationEvent(GeoServerSecurityManager.java:410)
Caused by:
at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.handleInvalidKeyException(StandardPBEByteEncryptor.java:999)
at org.jasypt.encryption.pbe.StandardPBEByteEncryptor.decrypt(StandardPBEByteEncryptor.java:976)
at org.geoserver.security.password.URLMasterPasswordProvider.decode(URLMasterPasswordProvider.java:134)
at org.geoserver.security.password.URLMasterPasswordProvider.doGetMasterPassword(URLMasterPasswordProvider.java:80)
at org.geoserver.security.MasterPasswordProvider.getMasterPassword(MasterPasswordProvider.java:35)
at org.geoserver.security.GeoServerSecurityManager.getMasterPassword(GeoServerSecurityManager.java:1864)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-sha1:7e8526a)
Atlassian logo
