Ian Turton created an issue |
Issue Type: |
Affects Versions: |
2.9-RC1 |
Assignee: |
Unassigned |
Components: |
Windows Installer |
Created: |
03/May/16 12:42 PM |
Environment: |
Windows 7 Ultimate SP1, |
Priority: |
Reporter: |
When you use the Windows installer to install geoserver and opt for manual start the generated startup.bat fails to start GeoServer with the message: G:\Program Files (x86)\GeoServer 2.9-RC1\bin>call “G:\java\jre\bin\java.exe” -DGY=geoserver -Djetty.port=8080 -Djetty.logs="G:\Program Files (x86)\GeoServer 2.9 Usage: java -jar start.jar [options] [properties] [configs] Can be fixed by adding -Djetty.base=“G:/Program Files (x86)/GeoServer 2.9-RC1/” to the start command so that Jetty finds start.ini - I guess there is a template somewhere that needs this added. |
This message was sent by Atlassian JIRA (v1000.5.1#72002-sha1:980ffbe) |
