Nuno Oliveira created an issue |
GeoServerPropertyOverrideConfigurer doesn’t properly substitute windows paths |
Issue Type: |
Assignee: |
Created: |
06/May/16 5:19 PM |
Fix Versions: |
2.8.4, 2.9.1, 2.10-beta |
Priority: |
Reporter: |
GeoServerPropertyOverrideConfigurer uses replaceAll() method to substitute GEOSERVER_DATA_DIR placeholders with GeoServer data dir path. Problem, the replaceAll() method uses regex instead of literal strings, so when substituting with an windows path this will produce a wrong result. For example, if GeoServer data dir path is “C:\Users\Work\GeoServer\data” and we have a property like this "jdbc:h2:$ {GEOSERVER_DATA_DIR} \db" the substitution will be: |
This message was sent by Atlassian JIRA (v1000.5.2#72002-sha1:b4422fe) |
