[Geoserver-devel] [JIRA] (GEOS-7535) Image has dashed horizontal/vertical lines when reprojected
Elaine Ting created an issue
GeoServer / BugGEOS-7535
Issue Type:
BugBug
Affects Versions:
2.9-beta2, 2.8.1
Assignee:
Unassigned
CHDE_RS2_2307_1_25904_screenshot.PNG, CHDE_RS2_2307_1_25904_with_whiteEdges_screenshot.PNG, CHDE_RS2_63045_1_32225_screenshot.png
Components:
WMS
Created:
08/May/16 1:05 AM
Priority:
MediumMedium
Reporter:
Elaine Ting
Originally asked about this here: http://osgeo-org.1560.x6.nabble.com/white-edges-appearing-around-GeoTIFF-image-td5262381.html#a5264399 and was advised to create an issue here.
The attached images show dashed lines (of empty space I think) when reprojected. I have attached the following:
CHDE_RS2_2307_1_25904.tif: image that has horizontal line near the top
CHDE_RS2_2307_1_25904_with_whiteEdges_screenshot: Due to GEOS-7270 - Edges of image with NoData have white artifacts when reprojected Complete , there are white edges around this image, and the white edges seem to align with the dashed lines.
CHDE_RS2_2307_1_25904_screenshot.PNG: screenshot showing the horizontal line when I previewed it in Geoserver. I noticed that if I change ‘Tiling’ to ‘Single Tile’ then this issue does not appear.
CHDE_RS2_63045_1_32225.tif: image that has vertical lines on both sides
CHDE_RS2_63045_1_32225_screenshot.png: screenshot showing the vertical lines
If someone can help to test to see if this is reproducible, that would be great!
Thanks in advance.
Eting
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.5.2#72002-sha1:b4422fe)
Atlassian logo
