[Geoserver-devel] [JIRA] (GEOS-7538) Monitoring plugin doesn't log remote user
Tim Vander Borght created an issue
GeoServer / BugGEOS-7538
Monitoring plugin doesn’t log remote user
Issue Type:
BugBug
Affects Versions:
2.8.3
Assignee:
Unassigned
Components:
Monitoring
Created:
10/May/16 2:38 PM
Priority:
MediumMedium
Reporter:
Tim Vander Borght
We are testing the monitoring plugin in GeoServer 2.8.3 and noticed that the user executing the request (RemoteUser) was never logged.
We noticed this behaviour with users from the default XML service and with users from LDAP (using LDAP authentication provider).
We’ve investigated this a bit further.
Both users from the XML service as users from LDAP implement org.springframework.security.core.userdetails.UserDetails.
In MonitorFilter (https://github.com/geoserver/geoserver/blob/2.8.3/src/extension/monitor/core/src/main/java/org/geoserver/monitor/MonitorFilter.java) however the remote user is only set when auth.getPrincipal() is an instance of org.springframework.security.core.userdetails.User, which is not the case:
if (SecurityContextHolder.getContext() != null
&& SecurityContextHolder.getContext().getAuthentication() != null) {
Authentication auth = SecurityContextHolder.getContext().getAuthentication();
if (auth.getPrincipal() != null && auth.getPrincipal() instanceof User)
{ data.setRemoteUser(((User)auth.getPrincipal()).getUsername()); }
Changing this code to check whether auth.getPrincipal() is an instance of org.springframework.security.core.userdetails.UserDetails and casting to this class instead would probably solve the issue.
Best regards,
Tim.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.5.2#72002-sha1:b4422fe)
Atlassian logo
