[Geoserver-devel] [JIRA] (GEOS-7554) GeoServer 2.9 may not start if native JAI is installed in the JDK/JRE
Andrea Aime [Administrator] created an issue
GeoServer / BugGEOS-7554
Issue Type:
BugBug
Assignee:
Unassigned
Created:
23/May/16 6:36 PM
Priority:
MediumMedium
Reporter:
Having JAI both in the webapp and in the JRE/JDK prevents startup with Jetty 9.
A simple workaround is to remove JAI from GeoServer WEB-INF/lib as suggested in the install guide (the difference being that right now the step is no more optional):
http://docs.geoserver.org/latest/en/user/production/java.html#geoserver-cleanup
So, two options:
  • Update the docs
  • See if changing the classloading options in Jetty makes it start anyways
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.5.2#72002-sha1:b4422fe)
Atlassian logo
