[Geoserver-devel] [JIRA] (GEOS-7565) Cluster settings - "Couldn't resolve model type..." warning
Maciej Filocha created an issue
GeoServer / BugGEOS-7565
Cluster settings - “Couldn’t resolve model type…” warning
Issue Type:
BugBug
Affects Versions:
2.9.0
Assignee:
Unassigned
Components:
UI
Created:
31/May/16 2:50 PM
Environment:
Centos 7.2, tomcat 7.0.69, java-1.8.0-openjdk
Priority:
MediumMedium
Reporter:
Maciej Filocha
Opening a “Cluster settings” tab throws following warning:
{WARN [form.AbstractTextComponent] - Couldn’t resolve model type of
Model:classname=[org.apache.wicket.model.CompoundPropertyModel$AttachedCompoundPropertyModel]:nestedModel=[Model:classname=[org.apache.w
icket.model.CompoundPropertyModel]:nestedModel=[
{toggleSlave=true, topicName=VirtualTopic.>, connection=enabled, brokerURL=tcp://ng7:61616, durable=true, xbeanURL=./broker.xml, toggleMaster=false, embeddedBroker=disabled, CLUST ER_CONFIG_DIR=/var/lib/geoserver/cluster, embeddedBrokerProperties=embedded-broker.properties, connection.retry=3, instanceName=ng6, readOnly=enabled, group=geoserver-cluster, connection.maxwait=10000}
]] for [TextField [Compone
nt id = toggleSlave]], please set the type yourself.}
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.25.1#100000-sha1:fa89b69)
Atlassian logo
