Jody Garnett [Administrator] created an issue |
Issue Type: |
Affects Versions: |
2.9.0 |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
09/Jun/16 9:33 PM |
Environment: |
GeoServer 2.9.x (configured with user_projections with conus.los and conus.las grid-shift files ) |
Priority: |
Reporter: |
Lets turn back the clock to a NAD27/EPSG:4267 data set:
When this data is published via GeoServer and displayed in an WGS84/EPSG:4326 map the results do not quite line up (see attached screen snaps). We expect this will require both:
We assume one of the systems is going through NAD27 → NAD83 and doing a small small transform to WGS84, while we assume the other system is just doing the ellipse shift. |
This message was sent by Atlassian JIRA (v1000.35.0#100001-sha1:291718a) |
