[Geoserver-devel] [JIRA] (GEOS-7579) Variable substitution not working if multiple layers are provided in WMS call
Martin Huber created an issue
GeoServer / BugGEOS-7579
Issue Type:
BugBug
Affects Versions:
2.8.0
Assignee:
Unassigned
Components:
WMS
Created:
11/Jun/16 8:50 AM
Labels:
wms cql variable-substitution
Priority:
MediumMedium
Reporter:
Martin Huber
The issue is related to cql expressions in the rastersymbolizer style element to make the color map dynamic as described here: http://docs.geoserver.org/2.8.x/en/user/styling/sld-reference/rastersymbolizer.html#cql-expressions
It works basically, but as soon as more than one layer are passed through the layers-parameter in a WMS call the cql parameters are ignored and the defined default values are applied.
As an example, the threshold1-parameter in the following WMS call is completely ignored because two layers are passed:
http://server:8080/geoserver/prog/wms?service=WMS&version=1.1.0&request=GetMap&layers=layer_1,layer_raster&ENV=threshold1:0&styles=&bbox=8…,48…,8…,48…&width=767&height=768&srs=EPSG:4326&format=application/openlayers
The issue was confirmed in the GeoServer user group:
http://osgeo-org.1560.x6.nabble.com/Variable-substitution-not-working-if-multiple-layers-are-provided-in-WMS-call-td5271011.html
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.35.1#100001-sha1:4aeecd8)
Atlassian logo
