Cyril Gallay created an issue |
Regression in rendering with transformation and TextSymbolizer with Halo |
Issue Type: |
Affects Versions: |
2.8.3, 2.9.0, 2.8.2 |
Assignee: |
Unassigned |
Attachments: |
raster.tif, screenshot-area-2016-06-15-091323.png, style-with-halo.sld, style-without-halo.sld |
Components: |
WMS, WPS |
Created: |
21/Jun/16 11:05 AM |
Priority: |
Reporter: |
A possible regression was found when rendering raster layers that use SLD files extracting contours (using WPS process gs:Contour) and a TextSymbolizer with a Halo. The screenshots shows artifacts that are rendered on the top left corner of tiles generated by geoserver. These artifacts are only visible if a Halo is set for displaying the values of extracted contours. Steps to reproduce :
This bug does not exists in GeoServer 2.7.1.1 |
This message was sent by Atlassian JIRA (v1000.73.0#100002-sha1:aa24b46) |
