Andrea Aime [Administrator] created an issue |
Add support for dynamically choosing jpeg or png compression based on output contents |
Issue Type: |
Assignee: |
Unassigned |
Components: |
GWC, WMS |
Created: |
24/Jun/16 4:37 PM |
Priority: |
Reporter: |
A new format, image/vnd.jpeg-png that supports transparency by encoding png if the map actually contains non opaque pixels (or if the image is paletted) and using jpeg instead if the image is fully opaque to get better compression performance and lower CPU usage. |
This message was sent by Atlassian JIRA (v1000.98.4#100004-sha1:567e5d0) |
