Alessio Fabiani created an issue |
Issue Type: |
Assignee: |
Created: |
05/Jul/16 6:36 PM |
Priority: |
Reporter: |
When using the static method “GeoServerExtensions.bean” in order to retrieve a bean from the ApplicationContext, if it finds more than one instance of the Class it throws a MultipleBeansException. The behavior is OK in general, but as a GeoServer Developer I would like the possibility of allowing it to check if the beans are an instance of ExtensionPriority and in that case just return the first one instead of throwing an Exception. This may be very useful as an instance when checking for ResourceManagers from the Security Context. If I have two plugins GeoServer won’t start. If I need to build my own ResourceManager which is a decisor for the others installed, I do not have the possibility of installing it along with other security plugins. |
This message was sent by Atlassian JIRA (v1000.126.1#100004-sha1:15ab2b1) |
