Katey Bilz created an issue |
Issue Type: |
Affects Versions: |
2.8.3, 2.9.0 |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
15/Jul/16 8:24 PM |
Environment: |
Windows 7-64 |
Priority: |
Reporter: |
Including a cql_filter with arithmetic expression before IN function (i.e. PERSONS/10 IN (247757.4)) results in a parsing error. The resulting map should just show Kansas as PERSONS IN (244574) matches that.
Error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Could not parse CQL filter list.
Encountered “/ 10 ) IN” at line 1, column 9.
Was expecting one of:
“/” <DATE_TIME> …
“/” <INTEGER_LITERAL> "” …
“/” <INTEGER_LITERAL> “/” …
“/” <INTEGER_LITERAL> “+” …
“/” <INTEGER_LITERAL> “-” …
“/” <INTEGER_LITERAL> “)” “*” …
“/” <INTEGER_LITERAL> “)” “/” …
“/” <INTEGER_LITERAL> “)” “+” …
“/” <INTEGER_LITERAL> “)” “-” …
“/” <INTEGER_LITERAL> “)” “not” …
“/” <INTEGER_LITERAL> “)” “like” …
“/” <INTEGER_LITERAL> “)” “ilike” …
“/” <INTEGER_LITERAL> “)” “exists” …
“/” <INTEGER_LITERAL> “)” “does-not-exist” …
“/” <INTEGER_LITERAL> “)” “is” …
“/” <INTEGER_LITERAL> “)” “between” …
“/” <INTEGER_LITERAL> “)” “=” …
“/” <INTEGER_LITERAL> “)” “>” …
“/” <INTEGER_LITERAL> “)” “<” …
“/” <INTEGER_LITERAL> “)” “>=” …
“/” <INTEGER_LITERAL> “)” “<=” …
“/” <INTEGER_LITERAL> “)” “<>” …
“not” …
“in” …
“tequals” …
“before” …
“after” …
“during” …
“/” <INTEGER_LITERAL> “not” …
“/” <INTEGER_LITERAL> “like” …
“/” <INTEGER_LITERAL> “ilike” …
“/” <INTEGER_LITERAL> “exists” …
“/” <INTEGER_LITERAL> “does-not-exist” …
“/” <INTEGER_LITERAL> “is” …
“/” <INTEGER_LITERAL> “between” …
“/” <INTEGER_LITERAL> “=” …
“/” <INTEGER_LITERAL> “>” …
“/” <INTEGER_LITERAL> “<” …
“/” <INTEGER_LITERAL> “>=” …
“/” <INTEGER_LITERAL> “<=” …
“/” <INTEGER_LITERAL> “<>” …
Parsing : (PERSONS/10) IN (247757.4).
This message was sent by Atlassian JIRA (v1000.148.3#100005-sha1:53b5f3f) |
