Daniele Romagnoli created an issue |
Secured decorators doesn’t handle Structured GridCoverage2DReader |
Issue Type: |
Affects Versions: |
2.8.4, 2.7.6, 2.9.0 |
Assignee: |
Unassigned |
Components: |
Main, Security |
Created: |
19/Jul/16 10:56 AM |
Priority: |
Reporter: |
When trying to delete a granule from an ImageMosaic on a Secured GeoServer, the operation doesn’t succeed returning this message: The problem is that the DefaultSecurityFactory wraps the reader with a SecuredGridCoverage2DReader which implements standard GridCoverage2DReader. Granules management can only be performed on StructuredGridCoverage2DReader so the Factory should wrap that interface with a SecuredStructuredGridCoverage2DReader implementing it. When doing that, it should also take care of checking the wrapping policies and filters for operations like read, harvest, granules removal, coverage removal and so on. |
This message was sent by Atlassian JIRA (v1000.148.3#100005-sha1:53b5f3f) |
