Daniel Araujo Miranda created an issue |
Issue Type: |
Affects Versions: |
2.9.0 |
Assignee: |
Unassigned |
Components: |
GWC |
Created: |
22/Jul/16 4:51 PM |
Environment: |
Ubuntu 16.04, Tomcat 8, Nginx reverse proxy |
Labels: |
geoserver web |
Priority: |
Reporter: |
Original Estimate: |
1 hour |
Remaining Estimate: |
1 hour |
Geoserver tiled layers preview points to http://127.0.0.1:8080/geoserver/gwc/… even though “Proxy Base URL” is set correctly. The regular layer previews work as expected. This is the code to create the WMS demo page links (which works): This is the code to generate the GWC (tiled) demo page links (which does not quite work): It seems that the problem is in the GWC demo page generation which does not pull the getGeoServer().getGlobal().getSettings().getProxyBaseUrl() property. The “actions” links have the same problem: |
This message was sent by Atlassian JIRA (v1000.184.1#100008-sha1:1fb1cc9) |
