[Geoserver-devel] [JIRA] (GEOS-7656) Geoserver does not start on tomcat 8 in linux environment. Spring bean creation of gml32FeatureTypeEncoder fires java.lang.StackOverflowError
Petyo Zafirov created an issue
GeoServer / BugGEOS-7656
Issue Type:
BugBug
Affects Versions:
2.8.4, 2.9.0
Assignee:
Unassigned
catalina.2016-07-26.log, catalina.out, localhost.2016-07-26.log
Components:
Configuration
Created:
26/Jul/16 1:50 PM
Environment:
OS:
Oracle Linux Server release 7.2
GDAL:
gdal.x86_64 - 1.11.4-1.el7
gdal-java.x86_64 - 1.11.4-1.el7
JAVA:
java version “1.8.0_91”
Java™ SE Runtime Environment (build 1.8.0_91-b14)
Java HotSpot™ 64-Bit Server VM (build 25.91-b14, mixed mode)
JAI installed as it is described in documentation: http://docs.geoserver.org/stable/en/user/production/java.html
TOMCAT - tested with these versions:
apache-tomcat-7.0.70 - with java version 1.7
apache-tomcat-8.0.36
apache-tomcat-8.5.4
the content of used setenv.sh is:
#! /bin/sh
export CATALINA_OPTS=“$CATALINA_OPTS -Xms512m”
export CATALINA_OPTS=“$CATALINA_OPTS -Xmx4512m”
export CATALINA_OPTS=“$CATALINA_OPTS -Xss256k”
export CATALINA_OPTS=“$CATALINA_OPTS -XX:SoftRefLRUPolicyMSPerMB=36000”
export CATALINA_OPTS=“$CATALINA_OPTS -XX:+UseG1GC”
export CATALINA_OPTS=“$CATALINA_OPTS -server”
“data” folder is moved from <home>/<tomcat>/webapps/geoserver to <home>/geoserver_data
and GEOSERVER_DATA_DIR environment variable is created in .bash_profile file:
export JAVA_HOME=/usr/java/jdk1.8.0_91/
export GEOSERVER_DATA_DIR=/home/tomcat/geoserver_data
export GDAL_DATA=/usr/share/gdal
LIBRARIES:
jai_codec-1.1.3.jar, jai_core-1.1.3.jar, jai_imageio-1.1.jar
are removed from /<home>/<tomcat>/webapps/geoserver/WEB-INF/lib/
postgresql-9.4-1201-jdbc41.jar is moved from /<home>/<tomcat>/webapps/geoserver/WEB-INF/lib/ to /<home>/<tomcat>/lib/
Labels:
geoserver spring4
Priority:
HighHigh
Reporter:
Petyo Zafirov
After running the application server, tomcat fails to initalize the ‘geosever’ context.
All log files are in the attachment.
The error is :
26 Jul 13:40:35 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gml32FeatureTypeEncoder’ defined in URL [jar:file:/home/tomcat/apache-tomcat-8.5.4/webapps/geoserver/WEB-INF/lib/gs-wfs-2.9.0.jar!/applicationContext.xml]: Bean instantiation via constructor failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.wfs.xml.v1_1_0.XmlSchemaEncoder$V20]: Constructor threw exception; nested exception is java.lang.StackOverflowError
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.184.1#100008-sha1:1fb1cc9)
Atlassian logo
