Sorin RUSU created an issue |
WFS2.0 doesn’t contain srsName attribute for the top-most gml:Envelope element |
Issue Type: |
Affects Versions: |
2.8.4 |
Assignee: |
Unassigned |
Components: |
Validation |
Created: |
27/Jul/16 12:02 PM |
Environment: |
Windows Server 2012 R2 VM, running on 4 cores with 8 Gbytes of RAM. Version |
Labels: |
wfs gml32 validation boundingBox srsName |
Priority: |
Reporter: |
Original Estimate: |
3 days |
Remaining Estimate: |
3 days |
I have a geoserver endpoint serving INSPIRE compliant environmental data (EPSG:3035) as WFS 2.0 (GML 3.2) through AppSchema from a PostGIS (pg 9.4) database. There is a validation error for the WFS request if the “return bounding box with each feature” is checked. For the wfs:boundedBy element there is no declaration of srsName, and while that bounding box is correct and valid, since the srsName isn’t specified, GML validators, like the one from opengeospatial, http://cite.opengeospatial.org/teamengine/viewSessions.jsp, will not validate my GML, saying that the bounding box for WFS doesn’t have a SRS associated. This issue is with any WFS 2.0 generated GML3.2, none of the requests seem to generate the required attributes for the WFS’s Envelope (i tried both complex feature types as well as simple feature types: shapefile, direct postgis data connections etc). I have confirmed this issue with Andrea Aime as well as with Ben Caradoc-Davies: In a WFS request, for example administrative units (request: http://inspire.biodiversity.ro/geoserver/ows?service=wfs&version=2.0.0&request=getfeature&typename=au:AdministrativeUnit&featureID=BC) I get the following response: |
This message was sent by Atlassian JIRA (v1000.184.1#100008-sha1:1fb1cc9) |
